03 Monte Carlo SS 3800 Series ll
Old Jan 29, 2017 | 12:43 PM
MzNeon77's Avatar
Red face 03 Monte Carlo SS 3800 Series ll
Purchased this car with 154000 miles on it. Ran awesome for the 1st 400 miles. Now...... it has ZERO power when I attempt to accelerate. Weather I'm going 20mph or 50 mph. Also I will add "if" I can get it up to 50mph. I have had the following engine codes & I have had them cleared after replacing the part that was to fix the issue. Codes- P0300, P0132, P0138, P0117, P0108. I am not sure what to even attempt to fix next since now the check engine light is no longer on nor flashing. It seems to shudder when I attempt to give any acceleration. And I'm not why but it seems to idle fine & start fine. The engine revs normal if it is in Park or reverse. ANY input would be greatly appreciated. :-)
Old Jan 29, 2017 | 02:50 PM
plumbob's Avatar
Sounds like a clogged catalytic converter. Were the O2 sensors, MAP sensor and ECT replaced and misfire corrected. Misfires can cause the cat to clog prematurely.
Check out these videos:
1. https://www.youtube.com/watch?v=Tj5NX1Ipfag
2. https://www.youtube.com/watch?v=TxP8SOpOG7Y
Old Jan 29, 2017 | 05:14 PM
MzNeon77's Avatar
Those 3 senors were replaced & the light was cleared on the dash. However it made zero difference n how it runs. I held my hand over exhust & it has plenty of flow. It did not appear cloged.
Old Jan 29, 2017 | 06:26 PM
plumbob's Avatar
It doesn't have to be completely clogged, just restricted.
Old Jan 29, 2017 | 07:29 PM
MzNeon77's Avatar
The only code now that will come on if I attempt to drive it normal is P0300 and that is multiple misfire detected, etc: and it will go off after flashing.
Old Jan 29, 2017 | 09:43 PM
plumbob's Avatar
P300 could be a few different things (plugs, plug wires, coil pack(s)), but I would bet money that it's the Cat. It will also set code P300.
Check out this video: https://www.youtube.com/watch?v=_92Y8bvO_ww
Old Jan 31, 2017 | 08:00 PM
SuperchargedMonte's Avatar
I had a friend with this problem on a 4.3 Vortec and it was a dirty MAF sensor. I hope you figure it out.
