01 monte carlo ss Wont stay started
Old Jun 5, 2020 | 03:04 PM
Caa213's Avatar
Default 01 monte carlo ss Wont stay started
Hey so im working on my fiancés monte carlo with the 3800 in it after it warms up it starts sputtering, backfiring and eventual stalls. Ive replaced the evap purge valve, throttle position sensor, mass air flow, spark plugs and wires , and the camshaft position sensor. Any ideas what it could be.
Old Jun 5, 2020 | 03:09 PM
Do you have a way to monitor data? Sounds like once the car warms up and goes into closed loop it is failing. You can check the oxygen sensor
Old Jun 11, 2020 | 09:35 PM
RedandBlackSS's Avatar
Bear in mind I don't know much about this stuff, but I always wonder... if it's getting enough air, it getting gas? How is your fuel filter?
Old Jun 11, 2020 | 09:36 PM
Caa213's Avatar
It ended up being the ignition control module
Old Jun 11, 2020 | 09:41 PM
Good to know. I just bought an '01 SS. Was that a big job?
Old Jun 11, 2020 | 09:43 PM
Caa213's Avatar
No super easy just take off the coil packs and its right under the coil packs
KyMonteSS
Feb 7, 2021 01:09 AM
Miss_Carlo88
Nov 17, 2018 12:16 AM
Kantor502
Sep 17, 2016 02:37 PM
jwjones
Feb 12, 2012 06:42 AM
Vladimir
Jun 10, 2009 05:12 PM
