00 Monte carlo Idle problems
Old Feb 21, 2010 | 07:21 PM
00'MonteSS's Avatar
Default 00 Monte carlo Idle problems
I have a 00 Monte Carlo SS and it when idling the RPMs jump around a lot between 500 and 1000. I just replaced the Spark plugs and wires, replaced the IAC, cleaned the TB and ran seafoam through it and it still does it, The check engine light is on but I don't know how to get the codes and its been on before this started happening. Any ideas what is causing this?
Old Feb 21, 2010 | 07:42 PM
mak330's Avatar
sometimes my car does this w/ the remote start. as soon as i put the key in its fine though.
throttle positioning sensor???
torqe converter???
GL im sure someone with more knowlage will chime in
Old Feb 21, 2010 | 07:46 PM
could be a catalytic converter problem?
Old Feb 21, 2010 | 07:50 PM
Wilco's Avatar
Could it be a faulty/dirty MAF?
Old Feb 21, 2010 | 11:08 PM
Dbl_D718's Avatar
Go to Autozone and get your car scanned for the codes. This could save you all sorts of guess work trying to figure out what the problem is. Getting your car scanned is free anyway.
Old Feb 22, 2010 | 08:46 AM
How did you clean the TB?
Old Feb 22, 2010 | 05:02 PM
00'MonteSS's Avatar
Pulled the air cleaner off and used snap ring pliers to take that screen off and sprayed the hell out of it with TB cleaner.
Another thing I forgot to add the car has only 102k and when I am driving it at like 55 the car will shudder really bad and I put it in Neutral and the RPMs jump like crazy, then when its idling I give it gas really fast and it kills over plus the thing lost a lot of power.
Old Feb 23, 2010 | 08:47 AM
The catalytic converter does sound like a good culprit.
The reason I asked about cleaning the TB is that you might have destroyed your MAF sensor by using a product that isn't made for it. Disconnect the MAF and see if your idling becomes more normal or not. If it still does it, then perhaps you can get your cat checked out.
Old Feb 23, 2010 | 10:59 AM
Dbl_D718's Avatar
Did you get the codes? Because they might have the answer...
Old Feb 23, 2010 | 12:14 PM
00'MonteSS's Avatar
I will try that, it might be the cat I always smell rotten eggs.
Not yet I might this weekend.
hondadbing116
19
Jun 22, 2012 07:33 AM
SS Monte
Jul 26, 2010 08:31 AM
nlange
Oct 11, 2009 11:21 AM
vita
Oct 21, 2007 12:17 PM
jamielee
Sep 6, 2005 07:22 PM
