MCF Website Problems & Issues This area is for problems or suggestions relating specifically to the MCF site, not the car.
Info: 2003 monte carlo headlights not working
Old Aug 13, 2023 | 09:58 AM
TiredPerson's Avatar
Default 2003 monte carlo headlights not working
My headlights decided to stop working checked fuses all good. My high beams work fine and fog lights work. Also noticed intermittently my turn signals will not work. Any ideas what to look at?
Old Aug 14, 2023 | 08:43 AM
Id check the switch itself using a multimeter and the car's electrical diagram.
Old Aug 23, 2023 | 04:37 AM
maxwesllcarlow's Avatar
Headlight Bulbs: Even if both headlight bulbs went out at the same time, it's possible that they both burnt out. Inspect the bulbs to see if they are visibly damaged or burnt.
Headlight Relay: There could be a faulty headlight relay that controls the power to the headlights. Relays can sometimes fail, causing issues like this. Locate the headlight relay in your vehicle's fuse box or relay box and consider swapping it with a similar relay to test if that resolves the issue. By the way I know that for example online casions can be played on a tablet, by the way https://casinosanalyzer.com/online-c...egascasino.com the information on this casino is correct. Switches: The headlight switch could be malfunctioning, preventing power from reaching the headlights. Similarly, the turn signal switch could be causing the intermittent turn signal issue. Try operating the switches multiple times to see if the lights come on or the turn signals start working.
Wiring and Connections: Inspect the wiring and connections around the headlights and turn signals. Look for any damaged or corroded wires, loose connections, or frayed cables. Sometimes, worn-out wiring can lead to intermittent issues like the ones you're experiencing.
Benji
Aug 26, 2020 01:27 PM
Myshell Ray
Mar 22, 2017 12:51 PM
aubiegrl93
May 20, 2014 10:01 AM
aubiegrl93
May 20, 2014 09:31 AM
2000monte
Feb 9, 2008 03:14 PM
