What head unit harness do you use and how well does it work?
Old Mar 11, 2010 | 05:44 PM
Pure2sin's Avatar
Originally Posted by peoples 01 ss
to turn the **** u will need a small phillips and its the small hole i think on th left side. turn it to the rite, i was havin the same problem with sound till i turned it up now its sounds good(better then stock)
Are you using the GMOS-04 or GMOS-01? But yes I have both of the gains on the interface all the way up. I still can't get good sound out of it.
Old Mar 11, 2010 | 06:47 PM
iMSeRiOuS's Avatar
I'm thinking about just running wires from my deck to directly to the factory speakers
Old Mar 11, 2010 | 10:40 PM
Dbl_D718's Avatar
Since you have an aftermarket head unit, I'd say just by-pass the stock amp. In all honestly, it's so weak that your head unit probably makes close to the same power, possibly more but I don't know the factory amp's specs. Just unplug the harness to the factory amp and connect the input and output wires for each speaker.
Old Mar 11, 2010 | 10:49 PM
peoples 01 ss's Avatar
i have a gmos 04
Old Mar 28, 2010 | 12:43 AM
iMSeRiOuS's Avatar
How much power are your pre-outs giving?
The deck I have has 5v pre-outs and I'm getting better sound than I did with my old one which only had 4v preouts.
My deck also has a lot of other specific settings which helped me get more/better sound.. but more volts = more sound. You can start by looking at the deck you are using.
Old Mar 28, 2010 | 10:37 AM
2002MonteSS's Avatar
I just installed a Scosche GMLAN2SR interface and everything seems to be working just fine. The chime sounds the same as the factory one.
I paid $15 for it on ebay, and yesterday I saw it at walmart for $50 so I did alright on the price.
Old Mar 28, 2010 | 01:37 PM
04MonteLS's Avatar
I used the Scosche GMSR09....it worked in that it allowed me to play my aftermarket stereo but shortly after installing the system I began having loads of mysterious/phantom electrical problems which have since gone by-bye after putting my stock deck back in.
That being said, I don't know if the problems were due to the harness or the stock deck being out of the loop. Needless to say, I have since bought a stock deck relocation harness and will buy a new aftermarket deck harness just in case that is what the real problem was.....that way when I put my new system in I'll hopefully be problem free this time around.
Habbibie
Jun 27, 2013 01:09 PM
01MoneyCarloSS
19
Sep 17, 2011 04:10 AM
DJTJ
Aug 13, 2011 11:54 PM
2001youngss
Jun 11, 2011 08:09 AM
couch
Mar 19, 2008 04:14 PM
