unsure of what amp to go with
Just to clarify, the final ohm load will be 2ohms cause you're gonna wire the coils together in series on each sub and then run speaker wire from each sub to the amp which will then join each of your 4 ohm loads into a single 2 ohm load giving you 870 watts rms from that AQ. You are good to go!
I had that amp pushing a pair of ID12's at that impedance and it banged pretty damn good, i'm sure you'll be happy!
Since you cant wire your subs down to 1 ohm the AQ1200 would be a great choice, however if you want to save even more money without losing power or quality, go grab yourself an AP1501D. I believe it does 900 or 950 at 2 ohms and if you set your gains properly you should have no problem whatsoever. The AP1501D will run you about $150 or higher depending on where ya get it from, but still the AQ1200 would work well if you decided on that
