unsure of what amp to go with
i was just wondering if a Power accoustik BAMF 2000/1d mono amp would go well with my dual 12'' kicker cvrs? I know its probably not the best but i really don't want to spend over 200 on an amp...
Power acoustic (or however its spelled) is knock off. Although, I used to have one of the gothic series powering a 15" SPL and myself as well as everyone who heard it, said it was amazing sounding. I think they are great it never over heated and I never had any problems with it but they tend to only hit on very low notes. So, for a knock off, it is great!! Over all, I think its a decent amp. The subs and other stuff they have isnt so great though.
I didnt even mention this. The sub I had it powering was a comp sub so it was made to pretty much hit the lows. so it might sound better with 12's.
But if youre not wanting to go over 200 for an amp, I think youll be happy with it.
At a $200 price point you are at the verge of being able to a very solid, dependable, underrated, powerful and very capable amp, the AudioQue AQ1200D. This amp can be had from the manufacturer direct for $249 shipped and will blow your socks off! This amp will do nearly 1500 watts rms @ 14.4v! I think you would be lucky if that PA amp could break 1k watts. If you were to compare the internals of both amps, I assure you that you'd pick the AQ amp hands down. It's superior in every way and at $249 shipped there aren't many amps out there that can compete. It will also do 870 watts rms @ 2 ohms, which would be perfect for your subs power wise but it all depends on if you have single or dual voice coil subs and what ohm rating they are. Let me know
Yup....I understand being on a budget, but I also understand that in alot of cases you get what you pay for. Power Acoustic is definitely low end stuff, it powers up and puts out power but by spending $50 more than your budget you can get an amp that is way more solid/dependable, puts out more and cleaner power, is waaaaay more efficient and is a respectable midranger player in car audio.
Thanks guys, the AudioQue AQ1200D sounds like it will be a better buy and its not to much over what i wanted to spend.
These are the subs that i have so hopefully they will be a good match.
This Kicker 07DCVR122 features Dual 12" CompVR subwoofers loaded in a vented enclosure. If you are looking for a subwoofer with enclosure made specifically to Kicker's specifications, than this is for you! Subwoofer Specifications:
- 12" CompVR Subwoofers
- Power Handling:
- Peak: 1600 watts
- RMS: 800 watts
- Impedance: Dual 2 Ohms
- Injection molded cone woofer
- Ribbed santoprene surround
- 360-degree back bracing
- Alunimized coating
- Spring loaded push terminals and perimeter venting
- Textured steel basket
- Frequency response: 25-500 Hz
- Sensitivity: 86 dB
- Authorized Internet Dealer
- 1-year manufacturer's warranty (suibwoofer only)
- Dual 12" Vented Enclosure
- 3/4" MDF Construction
- Heavy duty black carpeting
- Embroidered Kicker logo
- Dimensions: 32-3/8" W x 16" H x 17-3/8" D (Bottom) x 13-15/16" D (Top)
Kicker 07DCVR122
Kicker 07DCVR122
- Power Handling:
- Peak: 1600 watts
- RMS: 800 watts
Good luck and finding one that does that much power at that impedance that's below $200.
