Uh oh?
dang, then im probably not hopping to a typex... if it was blown i dont think it would be moving and blowing as much air as it is in that vid. it still sounded like good clean bass like before so i dont think i should have a problem hopefully
Ya man.. I think its fine, just dont push it at its peak for long periods of time and I think it will be good..
But I do think that smell is an Alpine thing but not positive..
if you smelt the burning smell it means your burning the rubber coating from around the coils,just like a speaker wire burning.the coil wires touch sending a negative feed back to the amplifier eventually blowing the outputs in the amplifier. if you did smell that you either have the speakers wired wrong or have a amp way to powerful for the speakers. you should NEVER smell that , nomatter how long or hard u play your music. try this. http://www.crutchfield.com/S-Un5CyuO...rs_wiring.html
just tryin to help. if its wired incorrectly you will get that smell.
alright, wasnt getting mad at your, just wondering if you thought it would be anything else with that extra info lol
my amp is tuned right i believe, i will check it out tho again, it ran fine for quite a bit, it was the 2nd time playing the song about half way through that i started to smell it
Im not questioning your electronic ability, Im just saying, if you're not tuned PERFECT for your setup, you can roast even your speakers without an amp. That song (like I said), hits as llow as 13 Hz, thats almost too low for human ear to pick up on. But then again, as mentioned above, it might just be giving your coils a nice work out that they need.
And I would also like to take this time to suggest downloading "audacity" for your music needs, you seem like you're really into nice sound from your stereo and that software will let you play around with tons of audio tuning (I mean more than you could ever need). I played around with it and got one of those explode systems from walmart, (you know, the ones that come with the whole kit in a box) after a little tuning with audacity, I had that system sounding MEAN!!! At least give it a go, you'll be pleasanty SUPRISED, I promise... >>>>
http://audacity.sourceforge.net/
