Trac off/ ABS lights wont turn off??
Old Dec 22, 2015 | 09:29 PM
Legend's Avatar
Default Trac off/ ABS lights wont turn off??
I have a 2001 Monte Carlo ss. A couple weeks ago my car would be fine until I would turn the steering wheel, then the Trac off & ABS lights came on. Now the lights stay on all the time right at startup?? Any help?
Old Dec 22, 2015 | 09:42 PM
plumbob's Avatar
Most likely a bad ABS wheel speed sensor. Unfortunately, that sensor is an integral part of the wheel hub and can't be replaced separately. A good scan tool should be able to tell you which wheel it is.
Old Dec 22, 2015 | 09:50 PM
Legend's Avatar
Thank you for your help! I've been looking for what it could be on the internet and this is probably the problem
Old Dec 22, 2015 | 10:09 PM
plumbob's Avatar
Your welcome.
There are several threads posted on this site on how to replace a wheel hub.
Sometimes the sensor just needs to be cleaned, but if you have over 100.000 miles on your car you're probably due for new hubs. Usually the front ones go first.
Old Dec 22, 2015 | 10:15 PM
Legend's Avatar
Yeah it has over 100,000, my checkup time is due in a couple hundred miles, so I will be sure to get it checked out while it's in! Thanks!
Old Dec 23, 2015 | 04:59 AM
fatfig's Avatar
number two problem, unplug them and clean the connections, number three, check your harass for a short.....good luck
Old Jan 11, 2016 | 07:56 PM
culater365's Avatar
Unfortunately for me, I had my sensors in the front left and right hubs go bad, and the wiring for the left side had been broke, allowing rust into the wire and travel up at least 2 feet (as much as I took out). Id check anything you can, and hope yours arent like mine
Old Jan 19, 2016 | 12:49 PM
fleetwood1976's Avatar
i replaced both front hubs as scan tool had indicated and they worked great for about a week then light was back on. guess i will search for a short.
Old Jan 20, 2016 | 05:23 AM
fatfig's Avatar
