Stereo Ground 2001
Stereo Ground 2001
I am bashing my head with trying to find a nice ground in the trunk of a 2001 MC. My amps are in the back roughly. I haven't tried the seat belt bolt for the rear seats, but I'd like to try something else. Perhaps I need to sand off some paint in other areas to get this quality of ground, but I am not having luck. If ANY one has an a/m stereo please tell me where you put your ground. Thanks
RE: Stereo Ground 2001
I looked around and didn't really find anything, I did find something else. This might be a really stupid question I thought about it for a bit I am now wondering if I could use a strut mount bolt (just take only ONE)? There shouldn't be any danger using just one of the top mounting bolts. The super high tention one is inside the strut, so it I can't see it being a problem. I see two of them. This might be the bolts that you are talking about but I just wanna double check. thanks.
WOW I AM SO STUPID!!!! K I am hoping that no one will read this but it is a mistake and hopefully others will NOT learn from this cause its really dumb, but just incase if you put your power wire to a NEG terminal it won't work. Try putting your power wire to the POS terminal...I never had a problem with my ground, but thanks for the help with the locations suggestions.
I have 0\1 gauge, Im grounding to a back seat bolt with the paint around it scraped off... should be fine. runnin JBL\crown equip. getting the wire through the firewall is the hardest. Im still workin on that. Havent had time in a while.
