7th Gen ('06-'07): Screw Removal Help
Old Jan 6, 2017 | 04:13 PM
96z34man's Avatar
Default Screw Removal Help
So, I'm trying to replace the steering wheel audio control switch. Got the airbag off, no problem.
Once i did, I found that the screws that hold the switch on are Torx screws. No problem, I have the correct size Torx ratchet driver.
What IS a problem is, the SOB who previous owned the car stripped two of the three screws. They won't move.
My GF found a solution on the Internet that didn't work--putting a rubber band inside the holes to fill the spaces.
I tried drilling them out. I now have two round, very shiny larger holes in the center of the screws. Who knew GM had access to adamantium?
I could break the old switch off, but that leaves two plastic tabs behind which will prevent the wheel from going back together properly.
Does anyone have a solution?
Old Jan 6, 2017 | 06:59 PM
Mels SS's Avatar
I have never got that far in to that area can you put vicegrips on the screw?
Old Jan 7, 2017 | 01:07 PM
96z34man's Avatar
Maybe on the one that's toward the outside of the wheel, but the inner one is also set down about three inches down toward the steering column. I can barely get the Torx ratchet in there.
Old Jan 9, 2017 | 12:37 PM
Smile
I have TORX screwdrivers the old fashioned kind? That may be something to check on they have them at Harbor Freight, Lowes,Sears, and Some Ace hardware stores.
I hate when that is an issue.
There is a tool that I have seen to remove this stuff, a screw extractor but lowes has them according to google on the site. I think it was,at Ace too?
Once you get it off you might check a salvage yard to get the replacement item you need.
Old Jan 10, 2017 | 03:48 AM
RickCoMatic's Avatar
Stripped Allen's and Torx Fasteners need to be removed with a "Modified" EZ-Out.
Grind-off the point of the EZ-out so that the OD of the EZout "Just-fits" the ID of the drilled fastener.
BEFORE attempting removal, ... "SEAT" the EZout in the fastener with a couple of firm taps to make the tool bite BEFORE applying Undo torque.
Old Jan 12, 2017 | 12:58 AM
96z34man's Avatar
Yeah, I've gotten two different EZ outs since posting the OP, looked for the answer on Google before I got any responses here.
The problem is, neither of them actually drilled into the screws far enough for the EZ out part to get any bite.
Has anyone used a specific brand that works? The ones that don't are Speed-Out (from Home Depot) and whatever the house brand is at Harbor Freight.
Old Jan 12, 2017 | 08:14 AM
WBody's Avatar
If it were me, I'd get a dremel and cut a slot into the head and grab a flat screw driver. If you can't get a dremel you might think about another way to get a slot in there like a file, bending a file, some other way to cut a slot in, carving attachment with wand, ect. I'm not sure how much room you have to work with.
Old Jan 13, 2017 | 02:10 AM
You have to modify the EZout!
Grind-off the point ... until you have the EZout that can fit.
a). ]]]]]]]>>>>>>>>>>
b) ]]]]]]]>>>>>
