running amp wiring
Old Jan 13, 2007 | 06:54 PM
04MonteSS's Avatar
Default running amp wiring
Anyone have any tips on where i can run the power wire for my amp to the battery? there doesnt seem to be any suitable openings in the firewall.. please help!!!
Old Jan 13, 2007 | 08:17 PM
mickey's Avatar
Default RE: running amp wiring
LOL this is a hell of a question.
when i did mine it took me forever to find a place to run it threw then i finally drilled a hole and made sure i seald it real good.
but basically i did have to drill it. and even then it was no fun trying to find a place. but i had mine all the way down almost to the point of where the floor is almost flat close to the frame. and then you cna get it out of the way of moving parts under the car and also protect it .
the only other place i have seen it run or even thought it might be run threw the first wall would be ont he drivers side there is a main harness goign threw the fire wall. but even then it was not easy to get to.
Old Feb 2, 2007 | 09:26 PM
red06SS's Avatar
Try going from the inside of the car out. I have always had good luck like that. The gromet that holds the main harness is usually the easiest. Feed a bunch of power wire through and go fishing. Good luck.
Old Feb 8, 2007 | 01:44 AM
victoryred05's Avatar
Yea i poked my wire thru a grommet thru the passenger side and neatly aranged my fuse holder on top of on of the panels under the hood it looks like i should be thier What size wire are u using?? mine is the big 4 gauge wire so yea it was a little tough but worth it
1988BlackMonteCarloSS
Nov 21, 2014 12:05 AM
TonySS2007
Jun 30, 2011 02:01 PM
Jan 19, 2011 08:15 PM
Bobbo51508
25
Oct 15, 2010 07:38 AM
mj_duffy1989
Aug 17, 2007 02:28 PM
