replacing 6.5 fron components
Old Aug 26, 2013 | 04:45 AM
fullmetal jacket's Avatar
Default replacing 6.5 fron components
I just got some infinity 6.5 component with cross over. Could I directly hook it up to the current setup with out using crossover will it work with out. If I decide to use crossover how would I wire the crossover since the wires are split from the factory harness would I connect both negs to the - side and both + coming out of the main to the crossover
Old Aug 30, 2013 | 07:23 PM
Justin Myers's Avatar
Use the cross over..
I'm assuming this is a passive set up
On the Crossover:
1. Input: Speaker wire from amp +,- to the cross over
2. Output: Speaker wire to woofer +,- from the cross over
3. Output: Speaker wire to Component +,- from cross over
Edit: you will also need an amp matching the RMS ratings on your speakers I wouldn't advise coming from one you have pushing subwoofer/s
drewwins
Jul 1, 2013 08:49 PM
zmc1990
Jul 7, 2012 10:41 AM
matt210
Mar 7, 2010 12:13 AM
mickey
Aug 29, 2005 05:46 AM
