Rear-view camera installed & more mods!
Old Mar 25, 2012 | 11:53 AM
shotime105's Avatar
Really?? Where did you order them from?? And what size led and resistor did it come with?? I really wanna swap mine for led's too! I upgraded all the other bulbs to led's. Now I just wanna do the lock switches and window switches. Thanks
Old Mar 25, 2012 | 12:10 PM
zzapultimate's Avatar
I got them from ebay.. as far as the size goes you need T3 NEO WEDGE LEDs. Search ebay for "neo wedge" leds and they will come up. Make sure you get the shortest ones you can find otherwise they won't fit.
Something like this : eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old Mar 25, 2012 | 12:44 PM
shotime105's Avatar
I found some but they say "twist lock". Im not sure if there the right ones. I found some on superbrightleds.com NeoWedge series LED Lamp Specifications and here is some 2x T3 Neo Wedge 1-1210 SMD SMT LED White Cluster Instrument Dash Climate Bulb | eBay
Old Mar 25, 2012 | 12:45 PM
shotime105's Avatar
Did you have to solder them in??
Old Mar 25, 2012 | 01:03 PM
You are on the right track. There is no soldering required. These twist into a socket. HOWEVER, the drivers side window switch does require them to be soldered in. There is no twist lock spot on it, and the LED is inside the switch.
Old Mar 25, 2012 | 01:13 PM
shotime105's Avatar
OK! So only the driver side window switch needs to be soldered. I just wanna make sure.
Old Mar 25, 2012 | 01:15 PM
shotime105's Avatar
One more question. Will these work on the instrument cluster??
Old Mar 25, 2012 | 01:33 PM
BlownUptoHigh's Avatar
So:
Drivers switch- need soldering
Drivers lock/unlock- twist into a socket
Passenger switch- twist into a socket
Passenger lock/unlock- twist into a socket
is this right?
How many bulbs are needed?
Old Mar 25, 2012 | 01:42 PM
No, the cluster has a different size.
Originally Posted by BlownUptoHigh
So:
is this right?
Yes. 4 bulbs total, one for each switch.
Be sure to get the short ones. Some of them out there have a long clear lens on them and they will not fit because they are too long.
Old Mar 25, 2012 | 01:44 PM
shotime105's Avatar
