Opinion Needed: Rear speaker question
Old Dec 5, 2016 | 10:29 PM
owens91's Avatar
Default Rear speaker question
So I have a set of 6.5 Sony speakers in the rear deck of the car the rear right one has gone out well it's still plays but it is very low I was thinking about changing the speakers out what is the biggest size I can get for the rear deck ?
Old Dec 5, 2016 | 10:41 PM
owens91's Avatar
Old Dec 5, 2016 | 10:53 PM
owens91's Avatar
Old Dec 8, 2016 | 10:09 AM
RickCoMatic's Avatar
I'm running a set of 6x9 JBL 3-way's.
To get them in you need to a little bit of "SCULPTING" on the two cut-outs.
For a Custom Enlarging of the two holes I traced the Speaker on a firm cardboard box.
Breakfast Cereal Box opened, flattened and Ironed flat after giving it a spritz of Spray Starch.
Once you have the home-made pattern sheet ready, ... trace the speaker on the sheet.
Use a SHARP precision tool to cut-out the template. X-acto Knife or a Razor Cutting Tool w/ the Slider **** that extends the Blade letting you break-off Tip sections for a fresh end.
Position the template over the Stock Speaker Cut-out.
Anchor with masking tape.
Using a SHARPIE ... Mark the OUTLINE, ... Then, COLOR that whole little area needing to go with the SHARPIE ... So you SEE what needs to go.
I sculpted-away the colored area using a Variable-speed DREMEL Tool w/ FLEX-Wand attached.
Place 3 or 4 Cutting Disc together on the Bit.
Now, ... "Play Dentist"
WEAR SAFETY SHIELD / GOGGLES / or GLASSES
Find a comfortable speed that allows you to gently -- "ERODE-AWAY" -- the Colored areas marked for trimming.
Use a feather-light touch and SKIM-away where you need relief.
DO NOT RUSH-IT or the Cutting Disks will break-apart.
I went through a bunch of discs before removing the little bit of sheet metal that needed being enlarged just a little-bit!!
Old Dec 9, 2016 | 05:59 AM
owens91's Avatar
I had a set of Sony xplod 4 ways that were 6x9 they fit right in
