Rear speaker question
So I have a set of 6.5 Sony speakers in the rear deck of the car the rear right one has gone out well it's still plays but it is very low I was thinking about changing the speakers out what is the biggest size I can get for the rear deck ?
I'm running a set of 6x9 JBL 3-way's.
To get them in you need to a little bit of "SCULPTING" on the two cut-outs. For a Custom Enlarging of the two holes I traced the Speaker on a firm cardboard box. Breakfast Cereal Box opened, flattened and Ironed flat after giving it a spritz of Spray Starch. Once you have the home-made pattern sheet ready, ... trace the speaker on the sheet. Use a SHARP precision tool to cut-out the template. X-acto Knife or a Razor Cutting Tool w/ the Slider knob that extends the Blade letting you break-off Tip sections for a fresh end. Position the template over the Stock Speaker Cut-out. Anchor with masking tape. Using a SHARPIE ... Mark the OUTLINE, ... Then, COLOR that whole little area needing to go with the SHARPIE ... So you SEE what needs to go. I sculpted-away the colored area using a Variable-speed DREMEL Tool w/ FLEX-Wand attached. Place 3 or 4 Cutting Disc together on the Bit. Now, ... "Play Dentist" WEAR SAFETY SHIELD / GOGGLES / or GLASSES Find a comfortable speed that allows you to gently -- "ERODE-AWAY" -- the Colored areas marked for trimming. Use a feather-light touch and SKIM-away where you need relief. DO NOT RUSH-IT or the Cutting Disks will break-apart. I went through a bunch of discs before removing the little bit of sheet metal that needed being enlarged just a little-bit!! |
I had a set of Sony xplod 4 ways that were 6x9 they fit right in
