Rear Defog
Old Oct 31, 2007 | 10:23 AM
Nightmare!'s Avatar
Default Rear Defog
Hello All. 2001 Monte SS and the rear defogger stopped working. Looked inside fuse boxes, doesn't seem to have fuses. Any ideas. Inside the passenger fuse box is a breaker, which lies underneath the fuses, could it be that? I'd really like to do myself. I've replaced that small four prong amp in fuse area with no luck. Any help would be appreciated.
Thanx!
Old Oct 31, 2007 | 12:32 PM
Default RE: Rear Defog
Hi Janet,
Sometimes the electrical rear contacts are broken when cleaning
the back window in your Monte Carlo.
Look close at the little metal clip connector's, and see if
they are broken. If so they need to be soldered, & re-connected.
I hope that other MCF member's will notice your post, and
give their possible solution to your prob.
Good Luck to you. Make sure you come back to the MCF.
`Space
Old Oct 31, 2007 | 06:59 PM
mickey's Avatar
be very careful with soldiring on your glass. if it is to cold it will pop the window on you.
But there are some metal tapes for doing repairs on glass that might be a better choice. also easier to use with out burning anything
shovelhead pete
Mar 15, 2015 09:02 AM
USMCdevildog
Dec 17, 2010 09:05 AM
montecarlo48178
Oct 9, 2010 03:31 PM
5207234w
Feb 23, 2009 11:07 PM
indytruder
Dec 24, 2008 11:20 AM
