passenger side headlight hi/low beam doesnt work
i have a 2001 Monte my passenger side headlight doesnt work the high beam doesnt work or the low beam doesnt work i switched both the high beam & low beam bulbs and the problem is still there,but heres the funny thing the side marker light works has anyone had this proble before???
heres an example of what i meant when i said my passenger side high beam or low beam doesnt work but my marker,turn signal,hazard, park lights etc. works fine all driver side headlights signal,marker, park,hazard etc.work fine i checked both bulbs both are good i dont seem to kno what the problem is has else anyone experienced this dilemma b4???
thanks i will try the ground but after i switched the low beam bulb again all lights are on now(hi/low beam markers) but u can tell that the lights are not getting enough juice because they look dim thats in the daytime while in park,shift it to drive all lights remain on DRL's dont come on anymore but at night the driver side light shines bright and i noticed the high beam bulb lit up on the passenger side all lights are on both high/low beam but are dim
