new alternator?
Old Dec 18, 2007 | 01:05 PM
schmicr's Avatar
Default new alternator?
if i wanted to add an extra battery for my sound system stuff to run off of would i need a new alternator with a higher watt rating or just a capacitor?
Old Dec 18, 2007 | 02:41 PM
kweef's Avatar
Default RE: new alternator?
all i have for my sound system is the capacitor...
Old Dec 18, 2007 | 05:20 PM
bonang's Avatar
Ok I might as well add my 2 cents and get 1 cent in change.
First Caps are band aids. Yes I used em in the past but there not helping your cars electronis.
Fisrt off you have to ask the question "Why do you want to add a extra battery?" Is there a reason. This is what should be done if your having electrical issues in the car ie. Dimming of dash and headlights.
1. Big Three
- Add 4 awg (at least) from the alt to the battery
- Add 4 awg (at least) from the Battery to the starter
- Add 4 awg (at least) from the ground of the battert to the Ground in the Chassis.
This will help in currect flow. The best thing you can do for a sound system. It also helps in bass hits if your into that.
2. Swap stock battery to a Yellow top deep cycle battery. These are great for sound systems and high curent flow.
Now if you still have a issue with current flow maybe look at the amp power wire you have. Is it a cheap sire that is brital? Might need to upgrade to a brand like street wires or Monster cable.
Now the cap. A Cap will help in keeping a steady 13 yes 13 volt to the system. Sometime there 12.5. My PG 1F cap is 13volt when charged. Caps are scary if they fail. I had one fail and it made a mess. Thank god it was not in the car.
If I am way off topic here let me know.
coolfonz
Jun 16, 2011 01:41 AM
charvel5150
May 6, 2007 10:43 PM
rrobert05
Mar 25, 2007 12:34 PM
busterdog
Jun 21, 2006 07:18 PM
bobsicparts
Oct 29, 2005 08:14 PM
