Name of PART TYPE ?!?!
What is the name or type of part of the following:
They are plastic with "ribs" & hold our door skins on the metal chassis, ... they "twist" into the slots into the skins. Bigger, more aggro ones hold the rear, carpeted deck down - the deck that covers the rear speakers ...
They also hold other plastic trim in place, etc.
Hi `Zeke,
Is this a test ?...Will there be a grade ?
If so, I failed
I hope one of our expert tech members will be able to answer your question
* If all else fails, call your local Chevy Parts Dept (?) & confuse them ~>
Hopefully they will know
, or should know (?)
Good Luck <~> Seriously
0r
Do you already know & just testing us ? Is this a new MCF Game ? ? ? ? ? LOL
If so, I failed
, or should know (?)Good Luck <~> Seriously
0r
@Space: No, Sir. Definitely not a test whatsoever. I want to get all new ones so when I put my entire interior together, it goes nice & tight ... It would be fine the way they are now, but I am ****, & want new. Guess I have too much money to **** away on the little stuff.
Hi `Zeke,
Yes, I am a believer in "Perfection", when it comes to a Monte Carlo....
It would be great `if you took pictures & made a thread about your rebuild/mod's 4-Sure...Good Luck & we look 4ward to your updates..
Thanks Seattle `Mike for getting a A+ on Zeke's quiz
These ^^^ are commonly called "Plastic Rivets". I hope this is what you are looking for. They are available at any parts store. Some can get expensive at $5 each. Others, you can get a box full for $5. Good luck!
Yes, they are called several different names depending on the company that manufacturers them, but I provided the most common names (the names GM refers to them as) that will bring up the most results in a search.
