My System
Old Feb 14, 2011 | 09:33 AM
bonang's Avatar
Default My System
20ft of 1/0 KnuKonzeptz wire (Blue)
15 of 1/0 KnuKonzeptz wire (Black)
Yellow Top Under the Hood
Kenetick 600 In The Trunk
Distro Blocks and Fuse holders and Circut Breakers
Single 12" FI SSD Dual 1ohm sub
Kenwood 6.5 components (Mid Bass) in the doors Tweets in the Dash
Nothing in the rear (6x9s are there but not running)
Kenwood - KDC-X993
Bass Remote
X1200M eXcelon Gouriki Mono Digital Power Amplifier
Kenwood eXcelon 4ch (forget the model)
Custom Sub Box Built by me, fiberglassed,Rockgaurded and carpeted
-Box is tuned to 35 hrz for music
-Still hit a
300sqft of Hushmat in the doors and Trunk(rear seat area not done yet)
-Three layers in the doors two in the trunk
Under the Hood(Zip ties are now black)
Dash (old Bass **** from Rockford was removed, new one was not installed yet)
Tweets
4ch
Mono
Both
Sub
Battery
Old Feb 14, 2011 | 09:39 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
Pretty sharp looking setup!
Old Feb 14, 2011 | 10:24 AM
jaws2008's Avatar
GOT SPL
Looks like a fairly clean setup.
Nothing wrong with FI either
looks nice! i have a quick question tho, when you run an extra battery, how exactly do you wire that up? just run the power wire to there and then branch off from the battery?
Old Feb 14, 2011 | 10:33 AM
bonang's Avatar
Not a wise choice I did to be honest. Basicly connect the pos to pos and neg to neg. But in doing so the factory alt is charging both batteries. Next in the line of upgrades is a DC Power Alt. I have a circut breaker so when I go to shows I can play music and not kill the battery under the hood.
Old Feb 14, 2011 | 10:37 AM
jaws2008's Avatar
GOT SPL
For car shows I use the "battery tender" that attaches to the batt under the hood and keeps it at full charge all the time. I have it hooked up with ring terminals that has a plug on the other end. So when I want to use the "battery tender" I just plug it in to the wire and dont even have to touch the battery and then I dont have those ugly looking alligator clips either
Old Feb 15, 2011 | 08:52 PM
Milhouse's Avatar
Why was that not a wise choice? DC Power? Hope you aren't in any rush to get your product when you finally order. So when you're at a show you just trip the breaker so your starting battery is out of the circuit? Did you use an isolator?
Old Feb 15, 2011 | 10:26 PM
walkingonabullet's Avatar
you should have an isolator on that 2nd battery so they dont kill each other when the car is off. its basicly a high current relay that turns on with your remote wire.
good choice on alts though, i picked up DC"s 220 amp alt, works great.
Old Feb 15, 2011 | 10:48 PM
Milhouse's Avatar
So the isolator is only necessary if you play the system with the car off?
Old Feb 15, 2011 | 11:02 PM
no, it always should be their, because when one battery is half full, it'll start to pull from the other to charge its self, and the other will tug back to charge its self back up. sort of a tug of war. both batterys are always connected when the stereo is on, because the isolator turns on witht he amps, because its on the remote wire.
