Maing my own sub box
another thing to remember the bigger the box is the louder the system will be, and with a sealed box it takes more power to make the subs get loud, and with a ported box the subs can move more freely, which means it takes less watts to make subs pound. my 15 inch sub is in a 4.4 cubic ft ported box. if anything just use only 2 tens in a ported box, because i would bet money that 2 10s in a ported box would get louder then 3 10s in a seal box, with half the watts. just something to think about.
This couldn't be further from the truth. Ever been to an spl competition? The guys running 2 sub setups don't have massive boxes, they generally have smaller boxes than the manufacturer recommends for their subs because their goal is to get loud, not be acurrate and musical.
Ported boxes are more efficient though, in that it does in fact take less power to get the same output, but their construction is a lot more complicated. The OP never mentioned wanting a louder setup anyway.
Long story short, larger boxes do not automatically mean more output.
lol thats so not true, look it up. i know hes not asking whats louder. but a smaller box does not "make more noise the a larger one" a small box is good for higher frequency music like you rock and metal stuff, and larger boxs are good for your low frequency "the bass that shakes the car next to you" As a rule of thumb, big woofers need big boxes. And big woofers in big boxes need big ports. Hands down, ported boxes will get a LOT more output since the port effectively doubles the volume of air the speaker moves around tuning frequency. Of course the tradeoff is you need a LOT of space for the box. Ported boxes are always bigger than sealed for the same woofer and the port itself eats up a lot of volume. Also, bigger boxes will play louder (due to acoustics of speaker/box systems), big boxes with ports and powerful speakers require a lot of port area for the port to function effectively, and big area ports must be longer, and thus take up even more space.
http://www.soundsolutionsaudio.com/s...A%252d12.html#
Maybe you should email him and let him know he's giving out bad info and explain to him how it's done.
By your logic, only subs in big boxes can drown out mids and highs, while subs in small boxes can't. I don't think much more needs to be said.....
so come to find out cuz i got my subs for free they are 3 12" subs...the only prob is that the are 4svc and not 4dvc so to wire all three makes them run at 1ohm which my amp says it can handle but it would prob end up destroying it,,,so i am only going to use 2 subs wired for 2 ohms.....here is the subs and amps i am using
http://www.crutchfield.com/S-eZsg4ac...KAC-9103D.html
http://www.crutchfield.com/S-Se9Q93D...nce-1240w.html
i obv should use better subs but hey i got these (3 of them and a box) for $100
