Line Output Converter
Hello,
I bought the SVEN2 line output converter and I am confident I did it right but I don't think its working.
I put the 2 white wires to one side of the speaker and the gray wires on the other side... Input will be Wired and Output is RCA
Got some RCA Jacks ran it to my amp then amp to my sub and it doesn't do anything...
Did I do something wrong and if so what and is the black wire needed for anything?
RE: Line Output Converter
ORIGINAL: rpd709
Hello,
Hello,
From what it sounds like, you didn't do it right. The white speaker leads are the the left speaker, the gray are for the right. The wires w/the black stripe are negative. Once you wire it up correctly you should be good to go. The black wire is to ground the rca's, which isn't always needed, but if you notice engine noise/alt whine then you might want to try grounding them to see if that takes care of it. Another thing to note is that from what I can see, this LOC should only be run up to 60 watts per input channel, and since you have 2 input channels you shouldn't be running more than 120 watts off it. Which means you're overdoing it by running a sub amp off it. Just a heads up.
So how do I tap into the speakers before the amp
I called cardomain and their tech support said to tap into it after the amp becuase the factory radio doesn't really put out much wattage so will need the amp..
Geez Decisions!
ANYONE THAT HAS THIS SETUP PLEASE POST PICS OR ADVISE HOW YOU DID IT PLEASE!!!
Geez Decisions!
ORIGINAL: rpd709
Geez Decisions!
Geez Decisions!
It would probably be better to tap into the speaker leads coming out of the amp because you'll likely have a little bit more voltage on those lines since voltage times amperage equals wattage, so surely there will be more voltage on those lines than the ones coming out of the head unit.
So all you gotta do is connect the white wires to the left rear speaker and the grey wires to the right rear speaker, remembering that the colored w/black stripe is the negative lead, connect your rca's to the LOC and to the amp and you should know what to do from there. Have fun and good luck!!
But remember, you should only be running 120 watts via the LOC per specs, so if something gives up the ghost on you then you have nobody to blame but yourself. But in all fairness, i've used LOC's for quite some time and have yet to run into an issue like that so don't lose any sleep over it, hehe.
If you have the amp mounted under the rear deck, you actually don't even need a LOC.
With the premium sound setup, the signal between the radio and the amp is Line Level, so you can tap RCAs into those lines and run them right to the sub amp.
You really don't want to add a LOC after the amp because the amp reduces the amount of bass (on purpose) as the volume is turned up tp avoid blowing the factory speakers...
BBEngineer
BBEngineer
ORIGINAL: bbengineer
BBEngineer
BBEngineer
Can you give this guy instructions on how to tap rca's into speaker wires?
If you use LOC or high-level input on an amp connected to the output of the factory amp, you are still going to get bass reduction... There is no way around it if you take the output of the factory amp and use it as a source for either a sub amp or another aftermarket amp.
To tap in for RCAs you need the wiring diagram...
Here it is for 03-05 (00-02 is different)
You need to tap into each of the speaker pairs and attach RCAs (braided shield is negative, center signal wire is positive)...
Run the new RCAs to the amp and you should be all set
BBEngineer
BBEngineer
BBEngineer
BBEngineer
Thanks for the schematic!
ORIGINAL: 04MonteLS
I guess this can be debated till the end of time, but I have a setup currently that utilizes the signal after the factory amp to run my sub amp and bass reduction is a non-issue. The higher I turn the volume the louder the bass gets.
If you rewire and tap RCAs in before the factory amp, you should see an increase in bass (and in signal quality) over your current setup...
Let us know if you do it and how it goes
BBEngineer
