Lighter not working
Old Nov 28, 2007 | 11:26 AM
87 Monte SS's Avatar
Default Lighter not working
Does any anyone where the fuse for the lighter is located on a 1987 Monte ss? Or have any knowledge of the wiring for it? Want to put xmas lights and use phone charger but need lighter to work.
Old Nov 28, 2007 | 11:48 AM
Default RE: Lighter not working
Hi `Chad,
The location of your fuse box, should be in your owner's book.
I believe it's located on the lower section of your driver's side dash area.
Checking the fuse would be most logical thing to do first, if fuse is good you need to check for power, and ground at lighter unit. get a cheap test light and check for power in center of lighter without touching sides, test light connected to ground. if test light lights up you have power, and a bad lighter : (
Many auto supplies stores will check it free for you.
Be Patience, & I'm sure one of our expert member's will add
information/help for you.
Good Luck `Space
cornerview
Sep 17, 2010 02:49 AM
Jack The Ripper
Mar 17, 2010 03:32 PM
Seanzy
Jun 1, 2006 08:32 PM
desighitter
May 30, 2006 11:12 AM
01whitess
Dec 20, 2005 03:29 PM
