LED Tail Light Design
If you can pull this off its really going to look dynomite! That last one was perfect - they all look good. I'd be concerned about getting them all pointed in the same direction cuz LED's cast light sort of directionally. This is a very fun project
Heres what I like....
I like the first pic.....It almost represents an arrow...If the leds were just connected to the turn signal then it would definately indicate which way your turning....
Kinda reminds me of the older T birds with the sequential lights that flashed from the inside to the outside .... --------->
I think that would be Unique! especially for a MONTE!
Once you figure out how to configure everything....I just maybe interested in getting a set for mine from ya!
Great project! I contemplated converting a pair of OE tail lights over to LED before buying a pair instead. I just didn't have the time to dedicate to the project. I was thinking of using a board as support to lay my design out on and mounting them behind the lenses. Have you looked into LED strips to aid in keeping the lights aligned? I was looking at this place when I was doing research:
LED Taillights
Scroll down the page and they have LED strips with up to 60 lights in each strip. Good luck with your project!
LED Taillights
Did they ever make chrome tail lights for the 5th gen? If they did, I would almost want to start with those. Paint the inside of the housing black, then tint the heck out of them.
LED Taillights
LED Taillights
Thanks for the links. There are some cool things in there!!
Unfortunately no. There are zero aftermarket tail lights available for the 5th gen. I was planning on painting the inside of some stock housings black to help darken the look of them. However, I will not be tinting the outside of the lens because I have been hassled quite a bit from the cops about my tinted lenses. This is the main reason for this project. I want some legal looking taillights, but I want them to look sweet
