Just Changed The 6x9's On The Rear Deck
Old Feb 13, 2008 | 07:25 PM
Bxbootlegger's Avatar
Default Just Changed The 6x9's On The Rear Deck
Greetings, I just recently changed the rear speakers from stock to Infinity Kappas. I did this in anticipation of putting a sub woofer in the trunk. It definitely is crisper, but it seems that as I increase the radio volume past around half way that the bass reduces. I have an 03 SS with the stock rear amp. Would it be worth doing the amp bypass? I am not looking for more bass or volume from the setup (that's what the sub will be for) but I would like a little predictability. Can the stock radio be stable at 2 ohms? Thanks, Jim.
Old Feb 13, 2008 | 08:14 PM
bonang's Avatar
Default RE: Just Changed The 6x9's On The Rear Deck
Stock speakers I think are 2ohm....so yes. lol
Old Feb 13, 2008 | 08:23 PM
What I meant is, if you bypass the amp would the radio w/o the amp be stable.
Old Feb 13, 2008 | 09:08 PM
TheFullMonte's Avatar
it's stable without the amp but you gotta have an amp to hear it. ohms load is present in the amplifier not the head unit unless the h.u. has an internal amp, obviously...lol. also gotta have a Pac-Loc or an integration unit/dsp to create rca"s for your amp(s)
Old Feb 14, 2008 | 06:41 AM
sickofsoyo's Avatar
the stock headunit reduces bass at louder volumes to protect the stock speakers. I have the same problem with my new system. My subs get crazy loud as the volume goes up to 5, but dont get much louder after that.
Old Feb 14, 2008 | 07:52 AM
bonang's Avatar
Yeah, the deck can handle a 2 ohm load but if you have the stock amp, you wont get any sound via the Headunit if you bypass it. The stock deck does not have a internel amp.
Old Feb 14, 2008 | 08:02 AM
Is there any way to make the stock head unit stop doing this?
Old Feb 14, 2008 | 10:12 AM
bonang's Avatar
No. Its programed into the radio. The only way to bypass this is to isntall an aftermarket radio.
Old Feb 14, 2008 | 08:34 PM
I was under the impression that it was programed into the amp. Now as far as the stock radio not having an amp it does. I was looking for some insight before I take the time and bypass the amp. Here is a "how to" on bypassing the amp . http://impalahq.naioa.com/HowTo/Amp_bypass.html
Travis Smith
Sep 23, 2012 08:27 PM
stratonx
FWD Tech Guides '95-'07
Jul 18, 2012 02:42 PM
06LT3
19
Nov 29, 2010 05:16 AM
86Ls
Jan 1, 2008 05:23 PM
06LT3
Jun 20, 2007 07:16 AM
