i need help! ASAP
Old Jul 11, 2008 | 05:58 PM
schmicr's Avatar
Default i need help! ASAP
i am trying to get my amp to come on when the stock stereo does, i do not want my amp to have a constant voltage so its on all the time. when i turn my radio on i want my amp to come on, when i turn the car off and the stock radio shuts off i want my amp to turn off. any help??? i got no clue what is going on, its a 2000 SS...
Old Jul 12, 2008 | 11:17 AM
kweef's Avatar
Default RE: i need help! ASAP
wait so u havent changed anything with ur radio and ur stock amp doesnt want to turn on? is that what u mean?
Old Jul 12, 2008 | 02:26 PM
vita's Avatar
as in, onboard amp or aftermarket amp for subs? your going to need to put a switch in between the radio and the amp turn on wire. most aftermarket amps have it as the blue wire...
Old Jul 12, 2008 | 11:07 PM
MonteTank's Avatar
i ran a switch between my amp and the radio fuse on my fuse block, sooo whenever i want my amp/subs on, i have to manually flip the swtich... not a big deal. so u could do that if youd like.
Old Jul 13, 2008 | 12:12 AM
schmicr's Avatar
ok i figured it out on the fuse panel to the left of the driving wheel is a brown wire which is the second accesory wire, that way when you turn the key to acc only the radio and a few other things work. so i cut the brown wire and wired my remote amp wire into it so that it will be on whenever my radio is.
zk6216
Mar 11, 2008 11:19 PM
mickey
Jun 4, 2007 09:57 AM
ajsbengals
May 5, 2007 04:32 PM
87monte
Jan 25, 2007 05:14 AM
mickey
Aug 17, 2006 01:31 PM
