How to turn off headlights?
Old Apr 21, 2010 | 08:47 PM
Cut Throat's Avatar
Default How to turn off headlights?
No, I'm not stupid enough to have the headlight switch turned on the whole time. But whenever its mildly dark out my 1998's headlights automatically pop on when the switch is in the off position. Now sometimes at night I'd prefer to have the car running but lights off. With the automatic headlight sensor thing-a-majig it won't let me. Is there anyway I could change it so I can actually control when my lights are on?
Also, are the driving lights that are always on able to be turned off manually? or is there a fuse I could pop out?
Old Apr 21, 2010 | 09:10 PM
it might be a relay youd have to take out. not sure on that one though.
Old Apr 21, 2010 | 09:16 PM
mrl390's Avatar
Check and see if you have a DRL fuse somewhere. If there is, I would pull it and see what happens. Now Im not sure how to disable the automatic headlights, but I do know that if your e brake is on and you start the car at night, your lights dont come on. Only after you release the e brake do they come on. I just leave the e brake on if I want to run the car with the lights off. There is no reason I would ever need to drive the car at night with the lights off, and I dont recommend you do it either.
Old Apr 21, 2010 | 09:17 PM
Dbl_D718's Avatar
Pretty sure there's a DRL fuse you can pull and solve both of your problems. DRL means daytime running lights just FYI. If you pull the fuse, your running lights won't come on when it's daytime and your headlights will no longer automatically turn on when it's dark.
If you want those features and want to let the car to idle with the lights off sometimes, set the parking brake and the lights should turn off both daytime and nighttime.
Edit: mrl390 apparently types faster than me lol
Old Apr 22, 2010 | 11:37 AM
RickAKATed10's Avatar
Photobucket
I literally just did this. I pulled 2 DRL fuses out, and I no longer have daytime running lights, however, when it gets dark, my headlights still do automatically come on.
Old Apr 22, 2010 | 11:41 AM
okay its a fuse. i was thinking because of the auto on and off, that it would be a relay.
Old Apr 22, 2010 | 01:07 PM
puffins629's Avatar
I have a 98 myself and all i had to do is pull the fuse and then everything is in your control
Old Apr 23, 2010 | 08:14 AM
Cut Throat's Avatar
Puffins, which fuse did you pull exactly?
Old Apr 27, 2010 | 01:27 PM
puffins629's Avatar
It was my day time running lights fuse that controled the sensor on the dash
ronniemarlo
Jul 2, 2014 08:44 AM
jasonsmith
Dec 7, 2011 12:59 AM
5Ringz
May 25, 2010 02:44 PM
MonteTank
Jan 9, 2009 01:45 PM
kyle08
Aug 29, 2006 10:43 PM
