How to remove interior?
Old Jul 28, 2014 | 02:14 PM
Red Monte Carlo's Avatar
Default How to remove interior?
I need help removing these pieces on my 06 Monte Carlo. They're circled in the image... Im going to paint them and need them removed. Does anyone know how? Ill also need help on how to paint it so if anyone knows that as well to help me. Thanks
Old Jul 28, 2014 | 02:19 PM
Cool >Wait for a expert to advise `OK< (LOL)<
I think they just pop `off using a screwdriver or
a thin butter type knife (?)
I would wait for a member that knows for sure ?
I just posted to blow `up your picture.
Also, check the MCF Paint section > or do a search on this
topic. >Search (*at the top of each MCF page)
Good Luck
Oh, what color are you going to paint the panels ?
Old Jul 28, 2014 | 03:02 PM
Good Luck
Thanks! I dont want to mess it up so thats why im asking for some options.. Im most likely going to paint it red so that my interior will be black and red to match the outside of my car
Old Jul 28, 2014 | 03:46 PM
Highly doubt they come off that easy lol, heres a video for 00-05, but i would imagine its similar for 06-07
Old Jul 28, 2014 | 09:24 PM
How to Remove a 00-05 Monte Carlo Dash-red04montels-HD - YouTube
Thanks Ill see if it can be done
Old Jul 29, 2014 | 06:50 AM
Cool
LoL `Keane > Highly `Doubt (?) > LOL
One must think/act positive & then get a hammer >
Posted above to bump this thread & hopefully get a member that has removed these panels to paint (?)
Member's, please post/share/help > thanks
Old Jul 29, 2014 | 12:46 PM
I changed my mind about painting it red. I have something else that im going to do for it stayed tuned... But I do want to paint my door panels instead. Anyone know how to remove the door panels and what kind of paint I should use?
Old Jul 29, 2014 | 05:34 PM
Barovelli's Avatar
I knew I kept these pictures for a reason. It is all one piece and it all snaps in. Adjust the steering wheel all the way down and carefully work the tabs. The pictures show where the slots are - it helps to know where to put pressure.
Wiggling the gauge cluster part takes patience. Weak spot is to the right of the gauge cluster. I used a plastic car interior prying tool.
For door panels, see http://www.barovelli.com/projects/ca...edoorpanel.htm
Dash with trim removed:
Right side
Left side
Old Jul 29, 2014 | 06:26 PM
Wow, why does it have to be so complicated in the 6th gens
Old Jul 29, 2014 | 07:58 PM
Barovelli's Avatar
The snap together dash is amazingly rattle/squeak free too.
I want to put a speaker for my standalone bluetooth mod in the grey plastic strip that is below the cluster, and have some cool grill pattern drilled into it.
and the worst dashboard I ever had to disassemble just to change out the stereo is on a 2000 Honda CRV. Took so many parts off it felt like I was going to find the engine block after the next piece.
