how to remove the dash from a 1999 monte carlo ls
Old Jul 30, 2012 | 11:02 AM
musclecar's Avatar
Default how to remove the dash from a 1999 monte carlo ls
i was wondering if anyone knew how to remove the dash from a 1999 monte carlo ls thanks
Old Oct 3, 2012 | 09:18 PM
TheTanman's Avatar
Default Fairly easy to do
This may be to late to respond too, but i at least want to respond in case it can still help you or others. First take off the four screws that hold, what i call the kick plate, which is right t your knees under the dash. Then you have to put the gearshift in drive and move the steering wheel all the down to make it easier. (make sure to put the Parking brake on and if you want, something in front of the tires just to be safe) After that, carefully pull around the edges of the dash and work it off around the steering column . Im pretty sure that all you need to know to do it.
red04montels
FWD Tech Guides '95-'07
39
Aug 8, 2017 03:41 PM
walkingonabullet
May 1, 2012 08:26 PM
Duesu
May 31, 2011 04:33 PM
mickey
41
May 15, 2011 10:30 PM
bowtie8_3
Apr 13, 2009 02:53 PM
