how to fix broken rear defroster tabs?
Old Aug 19, 2012 | 07:51 AM
D_Spear's Avatar
Default how to fix broken rear defroster tabs?
Hi my rear defroster doesn't work. It bothers me so much, come to find out the tab broke off from the rear window. I guess when the guy tinted my windows years ago he kind of bent it because I remember it being bent, but now it completely broke off. What should I use to re secure it to the rear window to complete the circuit again? soldering is something I want to stay away from because of the angle, and the fact that I don't have one.
Old Aug 19, 2012 | 08:09 AM
Google rear window repair kits. I had to do it for my 2004 Monte. I don't have the link I used anymore.
Old Aug 19, 2012 | 08:13 AM
D_Spear's Avatar
cool I did find some I'll order it off in the internet if I half to, any local places? I have asked auto zone and Napa auto parts. I live in an area where everything is at. If anyone knows a place let me know plz.
Old Aug 19, 2012 | 09:36 AM
Auto zone would be worth checking out. I just do most of my auto-shopping on-line
Old Aug 19, 2012 | 12:24 PM
03SSLE's Avatar
I used the Permatex kit to repair the defroster tab on the rear window of my S10 Blazer:
http://www.permatex.com/products/aut...Repair_Kit.htm
Follow the instructions to the letter and you shouldn't have any problems. I let the repair sit overnight before I slid the wire terminal back on to the tab to make sure it had set up. It was easy to use, and the defroster was still working about a year later when I sold the truck. You should be able to find it at your local Autozone or O'Reilly parts store.
Old Aug 20, 2012 | 03:30 AM
Gib's Avatar
Gib
Default I fixed mine
I used a small loop of wire with a male terminal on one end. The other end I applied solder to. Then climb in the car and heat it together quick. The loop of wire provides more slack to make the connection without tugging on the solder joint.
Old Aug 20, 2012 | 04:38 PM
D_Spear's Avatar
so I have found out my local autozone has the Permatex kit in stock, weird because in my old town they didn't have anything like that. Anyways I'm going to fix it, maybe make a How to on it.
Old Aug 31, 2012 | 08:51 AM
Yellowjacket's Avatar
Lol must be a problem almost every Monte has. Going to Autozone today to get that stuff as well. And also happened after window tints!!!
Old Nov 15, 2012 | 12:35 PM
Sleeping Martyr's Avatar
thanks for this thread, guys!! i have this EXACT same tab broken and was about to ask what to do.. damned if that pictured doesn't look almost identical to mine!!
http://i307.photobucket.com/albums/n.../defroster.jpg
Old Feb 8, 2013 | 01:52 PM
MJClemm's Avatar
Looks EXACTLY like mine as well... Not long after a window tint job....hmmmmmm wonder if the tinting guys own Permatex....lol....
