how easy is easy ? HID install
Old May 16, 2009 | 04:39 AM
Mitchum5543's Avatar
Default how easy is easy ? HID install
so I have been thinkin about doing this for a long time and have now finally decided to do it. I have decided to get a set of 10K HID's but I keep hearing mixed stories on how easy it is to install. some say plug and play some say your gonna need a couple of hours I have a 03 monte carlo ss do I need a relay ? witch set is better ? or all the kits about the same quality ? where can I buy a good kit ? am I going to need to know how to wire stuff ? AHHH please help any links feed back advice would be of great help thanks everyone.
Old May 16, 2009 | 06:12 AM
Hope the below gives you some idea...Plus use Google & MCF Search Engine
for additional information. Also check back on your post to see what other member's have posted....Good Luck from `SPace
<LI about="r17">HID Lighting Kit Information and Installation
... replacement to your existing headlight bulb, yet are extremely easy to install. ... Installing a HID Lighting System Installing a HID kit is extremely simple ... 9004 HID Bi-Xenon HI/Low Beam Headlight Converson Kit 7500K HID Lights ...
www.slickcar.com/info_hid_kits.asp - 91k - Similar pages
http://www.slickcar.com/info_hid_kits.asp
<LI about="r18">How to install hid 9007 lights? - Yahoo! Answers
does anyone know how to install 9007 hid lights if…
answers.yahoo.com/question/index?qid=20090515220232AAPtLmI - Similar pages
http://answers.yahoo.com/question/in...5220232AAPtLmI
<LI about="r19">Video: Install HID Conversion Kit
http://www.qualityhids.com How to install HID Conversion Kit. ... Preview of Illegal HID Convesion Kits Explained View video 844 days ago ...
technorati.com/videos/youtube.com%2Fwatch%3Fv%3D... - 45k - Similar pages
Old May 16, 2009 | 09:18 AM
2000_BLACK_SS's Avatar
I got this kit from ZZp http://www.zzperformance.com/grand_p...=617&catid=101
took about an hour because i didnt really know what i was doing. i t was a direct plug and play kit. i had no problems with it at all. they where for my low beams.
here is a picture of where i installed the ballast. i just drilled two mounting holes and then bolted the ballast down into them.
Then i decided to get a kit off ebay for alot cheaper and had nothing but problems with it. Would always be blowing fuses it takes for ever for the bulbs to warm up and actual produce light.
i just would say go with a name brand on this one.
Old May 16, 2009 | 10:48 AM
gothkid's Avatar
what about carhidkits.com? there pretty cheap and look pretty legit
Old May 19, 2009 | 12:33 AM
hey kidspace thanks for links they did help out alot I did do a little more research carhidkits.com looks ok I also found planethid.com they look legit and reasonably cheap that seems to be my problem I do wanna go name brand but when it comes to this stuff I dont what is considered name brand name as 2000_black_ss said i really do think that is the way to go. but again to me 70 bucks seems kinda cheap for a kit like this so id like to go name brand and decently priced maybe space you could take a look at planethid and let me know what you think maybe ?
and thanks to everyone for their feed back its nice to be able to come here and get some help when no one I know knows the answer.
Old May 19, 2009 | 08:50 AM
RickAKATed10's Avatar
Photobucket
mavrickf1613
FWD Tech Guides '95-'07
28
Oct 9, 2012 10:20 PM
Berg01SS
Jul 21, 2009 08:59 PM
mavrickf1613
Oct 13, 2008 11:07 PM
2003supersport
20
Apr 22, 2008 11:01 PM
fastback4
Jan 15, 2007 02:16 AM
