Headlamp Switch Modification Project
Old Jan 19, 2016 | 10:59 AM
Rodney Smith's Avatar
Default Headlamp Switch Modification Project
Hello All,
I'm looking to see if I can get some help here. So I want to put a headlamp switch from a 2007 Monte Carlo into my 1972 Monte Carlo. I know it's a wide hope to get it done but I'm checking to see if anyone have any suggestions to assist me with this. I have the Wiring diagrams from the Haynes manual for both cars both I can't get the 2007 Headlamp switch to power up.
Thanks,
Rodney
Old Jan 19, 2016 | 11:26 AM
plumbob's Avatar
Hi Rodney.
I commend you for taking on this challenge, but I think your up against a good one.
I'm no auto electric expert, but you have to consider the technology gap. Specifically, trying to interface a system from an old technology car that has no BCM with components from one that does. The headlight dimmer switch from the '07 is built into the Multi-function switch which is partially interfaced with the BCM and a relay. Not sure how your 'gonna get that switch to work without a BCM. Maybe someone else here can give more insight on how to reconfigure the wiring to make it work.
I know you already have a schematic, but here's a couple for the '00 SS which should be very similar:
Attached Thumbnails Headlamp Switch Modification Project-headlights-control.jpg   Headlamp Switch Modification Project-headlight-power-distribution.jpg
