Interior LED Lights
Hey guys, I am looking to get an LED to go in my Monte. I was thinking 2 at the foot level in the front and then 1 underneath each the seats so that it lights up the backseat floor area as well. I am aiming low because I do not want it to bother anyone riding in my vehicle, for the same reason I am looking for some Dark red LED's, not bright red. I haven't worked with the electronic side of things on a car before so something that is easy to install without messing with too much wiring.
Any ideas and what I should go with? If you have a better position in the car for it for an awesome interior look I would love to hear it! Thanks again Cody |
I replace the lights under the das with red LED Pods from e-bay you can't see them unless ther are on (i repoved the stock bulbs)
I also use a 3 inch red LED strip under the radio to light up the cubby and map pockets in the door & changed the door light to red rather than blue Also I drilled a very small hole behing the inside door handles and inserted a single red LED bulb withed to the door panel lights this makes i look like the newwer luxury cars for sure http://i1190.photobucket.com/albums/...s/GEDC0008.jpg |
The door panel and under radio cubby is pretty awesome I did not think of that. I was considering getting this kit - LEDGlow - because you can adjust the brightness and also can make it go to the sound of your music. Apparently it has a microphone in the box. What do you think?
Also, back to the radio cubby and door panel, where did you get the 3in strip for it and where did you get your bulb for the door panel? Were they difficult to install? How did you do it? |
Originally Posted by Jethro
(Post 534776)
Also, back to the radio cubby and door panel, where did you get the 3in strip for it and where did you get your bulb for the door panel? Were they difficult to install? How did you do it? If you hook your light up to the right lead they will adjust to brightness with your dash light adjustment knob. I got the LED bulbs a radio shack and the LED strips from plasma glow. these link may be of interest to you https://montecarloforum.com/forum/si...ictures-29652/ At any rate the door panels need to come off - Locate your wiring to your door panel switch lights you willl hook into them I drilled a small hole behind the inside dooor handle well and pushed the LED light in (hole sligthly smaller than light) same for map well light strip just a small hole with a punch and pullded the strip wire through attached the strip to the map well wall wire to your door panel lifghts and they will dim with your dash light adjustment |
Well I always have my dash light knob adjusted to brightest so I wouldn't want them connected that way. How do you connect up a single LED Bulb like you did in your door panel? Never done it before so I am not sure.
(Post 534794)
our posts crossed in the mail :rotfl: see my post before youres |
I just replaced all of my interior lighting with white led bulbs from eBay, its Really Really nice and bright now. I replaced the 2 by foot area, the 2 in the rear view mirror and the dome light as well :)
(Post 534796)
(Post 534795)
My other only problem is that I have tan leather and not black, think the red will look weird with it? I don't really think will matter at night in the dark but who knows until I try right? |
Ya know my wife has tan in her 2012 Buick and her blue accent lights look really neat in it ..... Consider blue?
Well my car color is Dark Torreador Red (Maroonish) So I figured that the lower lit red ones would look better overall. Don't you think opening the door to see blue would be kind of weird looking in it?
