DIC problems
Here she is, I haven't named her yet. Just finished changing the oil and seafoaming her. Heres a vid of the results.
http://www.youtube.com/watch?v=KeKa_v48OS8
The DIC problems keep coming back, Once i smack it just right it'll work fine, but if i turn off the car, then turn it back on its gone again and i've yet to find the sweet spot to apply violence. I'm guessing its a wiring problem, you guys got any suggestions?
It's actually really easy. b while doing an oil change buy 2 cans, pour one in the gas tank when its full. Pour half of one into the oil, then disconnect the brake booster, start up the car, you'll have to give it a bit more gas to keep it alive. Have someone pour the sea foam into the brake booster slowly until youve used most of it, then dump it all. Shut off the car for a few minutes. Go on a joy ride, and change your oil in about 500 miles.
Oh yeah, then again i dont think its been cleaned since it was made. The throttle was more responsive, i got better mileage, smoother idle, plus the exhaust smells and sounds cleaner.
Instead, use the vacuum line that goes into the lower intake manifold
BBEngineer
Well I wish I would have known that earlier today... I guess whats done is done.
I don't mean to discredit you or anything, but can you show me something proving this? I've been googling it like crazy and everything i see about seafom in the brake booster says it works fine, even in an l67...
This is a good read, i want to seafoam but I do not want to put it on the booster line for same reason BBE posted, In this thread they mention to use a spot by the supercharge.. lemme find it
http://www.gpona.com/forums/do-it-yo...eup-t1391.html
*edit*
I don't know if this is true, and i have not done it myself.
Maybe we can clear this so that us boosting can seafoam ours.
*edit*
