Opinion Needed: Custom overhead console
Old Nov 5, 2021 | 06:32 AM
Metalunicorn00's Avatar
Default Custom overhead console
So when I got my car (03 SS), the overhead console was completely removed with the wires cut off. How would I go about building a new one and attaching it? I don't like the way the original looks, and since I gotta do the wiring anyway, I wanna make one that suits my taste in style. I mostly need help with the wiring part and ideas for materials
Old Nov 5, 2021 | 07:47 AM
Cool
This is something on my project list too! I visit some U-pull it yards now and then and I look for a console that might work.
No results yet but I am not giving up the ones I have seen were broken..
That would be my first go to. then you could also find the one that you have and see how it's wired get it and between the 2 of them you can customize what you like. Sunroofs are a problem? that has to be a shorter one.
Now as long as you are there take the headliner down and see once what it looks like so you know how to attach the custom one take pictures and measure it so see what you got.
Old Nov 5, 2021 | 10:00 AM
I've done a few back in my car audio days. IMO the easiest DIY option is to make it out of fiberglass (or the same technique with thin fabric as a sub for actual fiberglass).
Depending on how intricate the mount was, I'd usually hack off the base a factory one to build off of (so you're not trying to precisely replicate screw hole patterns / clip spacing / etc).
I dunno what to tell you about the wiring- that depends what all you want to put in the new one. If all you're doing is keeping the same factory buttons (just with a custom housing), I'd go buy a complete stock one from the JY and cut off a chunk of the harness behind the switch panel so you can splice it in.
ssdriver
Oct 13, 2022 06:53 AM
Larrysmonte
Mar 6, 2012 08:39 PM
mairj40
May 23, 2011 08:38 PM
Rocksteady
Dec 2, 2010 11:37 PM
