Changing Stock Amp
Old Aug 1, 2010 | 10:37 AM
MIKE07083's Avatar
Default Changing Stock Amp
Hey People....I have an Alpine amp. There is a pic of it with its attached wires below... Its the KTP-445 power pack. For those of you that dont know,its a small 45wpc booster amp made for alpine head units. I had this in my other car connected to a pioneer head unit,and it worked GREAT!...There are no preamp inputs or outputs,just wires corisponding to speakers and hot,ground and amp turn on...I was wondering if i could swap out the stock M/C amp for this amp. Just cutting the origional wire harness and connecting it into this amp...If anyone has any ideas,please let me know...Thanks in advance
Old Aug 1, 2010 | 11:12 AM
eviling's Avatar
of course you can, car has 4 speakers,(6 in some) a hot a ground and an ignition system of course it has all needed for this amp. the only thing i'd say to you is why? i doub the outputs on that micro amp are any larger than the stock monte amp.
Old Aug 1, 2010 | 12:13 PM
MIKE07083's Avatar
Well,I'll tell you...the alpine amp is a true 45wpc rms...Thats good clean power....The stock factory amp is at best 15 wpc rms....Thats a big difference...Another reason is that i already have the amp. I guess after allis said,im looking for a way to get rid of the factory amp and go with a better quality amp.
Old Aug 16, 2010 | 12:40 AM
peoples 01 ss's Avatar
You can cut out the stock amp and use the wire it will work fine just go to the12volt.com and it will give you the color wire for the stock amp
Old Aug 16, 2010 | 12:49 PM
eviling's Avatar
the stock amp only does 14 watts? no way has to do more than that, that stock amp sounded pretty good to me for a stock amp. the deck alone should be putting out 20 rms.
Hiroska
May 19, 2014 04:23 PM
dezzyboi16
Jan 21, 2013 12:16 PM
paintballerr78
Dec 10, 2009 09:40 PM
One Dark SS
Nov 11, 2009 11:34 AM
mcarloss04
Sep 21, 2005 03:10 AM
