Changing steering wheel
Change the steering wheel to just a universal Sparco one.. Just not sure on the adapter/hub I would need.
I can only find this as a "direct fit" https://www.carid.com/2005-chevy-mon...863016957.html
I dont know if a universal hub would work because of the small splines on the steering shaft.
I would say contact Flaming River to confirm fit to the steering wheel you want, I can't see there would be an issue with the steering column, it should be the same in 00-05 Montes & Impalas at least.
What are you doing about the airbag?
5th Gen ('95-'99): Steering wheel off Lumina
WyszukaneSamochody.pl
Aug 2, 2015 08:05 PM
BrandonStebing
Apr 19, 2015 07:18 PM
