Changing Radios
Old Oct 22, 2009 | 03:23 PM
05MCdriver's Avatar
Default Changing Radios
looking to replace the stock radio. what should i put in my 05 LS to look good? i am lookin for a touchscreen that would fit in the stock harness if possible but not a must.
Old Oct 22, 2009 | 09:11 PM
locknload's Avatar
http://www.crutchfield.com/S-0EbwlL0...car/mycar.aspx
Check out this link, they will tell you all the radios that will fit. You will need the different harness if you plan on keeping the door chimes and whatnot.
Old Oct 22, 2009 | 09:50 PM
ehhh who needs airbags and chimes and such...
get a good harness about 130 bucks...dont cheap it
Old Oct 22, 2009 | 10:05 PM
Dbl_D718's Avatar
I got my harness from PAC for right around 100 bucks and is IMO the best one available.
Also, your airbags will work just fine without getting one of those modules.
Old Oct 23, 2009 | 03:42 PM
air bag runs through most, or at least partially
Old Oct 23, 2009 | 03:53 PM
05MCdriver's Avatar
what radios do you guys got?
Old Oct 23, 2009 | 09:24 PM
Dbl_D718's Avatar
I have a Pioneer DEH-P880PRS. LOVE it. Simply an awesome headunit if you want to be able to adjust everything, especially if you ever want to do an active component setup.
Old Oct 23, 2009 | 10:56 PM
05MCdriver's Avatar
who knows anything about this one? Boss BV8965B
Old Oct 23, 2009 | 11:27 PM
Dbl_D718's Avatar
I didn't even have to look it up. It's made by Boss...it's junk.
I would suggest looking at these brands, as they're usually recognized as being "good" companies in terms of headunits: Pioneer, Eclipse, Alpine, JVC, Kenwood, Panasonic, and Clarion. There are definitely other brands that would be ok too, just some suggestions off the top of my head.
Last edited by Dbl_D718; Oct 23, 2009 at 11:42 PM. Reason: added something usefull to my post
Old Oct 23, 2009 | 11:57 PM
05MCdriver's Avatar
thanks for the heads up
