Camaro seats in 01 Monte Carlo SS FINISHED ! :)
Old Jan 21, 2014 | 06:14 PM
  #31
l67ss's Avatar
Not exactly. Had to drill two holes and enlarge the other two on each seat. Compared to these camaro seats theyre bolt in tho
Originally Posted by Nas Escobar
Those were a direct bolt on to your 97's frame though right?
Old Jan 21, 2014 | 09:36 PM
  #32
l67ss's Avatar
Any plans for the back seat?
Old Jan 22, 2014 | 09:37 AM
  #33
MJClemm's Avatar
As a matter of fact, yes... Same Camaro rear seats .. Trying to figure out if the work is worth the function and placement of them. A lot more fab work to get them in correctly and to have them function as good as the factory Monte seats , and for how many times the seat will be used to sit in, not sure if all the effort would be worth it. Don't get me wrong, I want all the seats to match, but I'd rather put thee time that it would take to do that and use that time on my rear Spoiler and front end with the new splitter....
Old Jan 22, 2014 | 11:28 PM
  #34
PacerSS's Avatar
Awesome man! Nice work, I remember a guy on clubgp that swapped seats on his Grand Prix with ones from a CTS-V, heated and air conditioned....I would definitely try this if I had the tools to fab something like that.
Old Jan 23, 2014 | 01:19 PM
  #35
MJClemm's Avatar
thanks... by the looks of your car i thnk yiou would be able to do this easily... believe me it wsnt very hard.... just took some measuring and cutting...... the steering wheel... now that may be mnore then i can deal with, but.... gotta try before i say it cant be done....... thanks...mjclemm
Old Feb 13, 2014 | 10:37 AM
  #36
brute_439's Avatar
I have a set of 2010 camaro seats I plan on installing in my 69 chevy c10. I'm not to great at wiring, any diagrams or tips you could give me would be much appreciated.
Old Feb 13, 2014 | 07:35 PM
  #37
Shelbo Mustang's Avatar
Seats look good! Do they have the heaters in them like the Monte seats? Cause I love my heated seats on cold days like today!
Old Feb 14, 2014 | 11:26 AM
  #38
MJClemm's Avatar
Hello and yes.. If you get the heated seats the picture shows the breakdown of the wires that I ran into... **** note.. I am NOT AN ELECTRICIAN by no means... This is what I did... Not sure if it's 100% correct! but it worked for me, if you deploy the air bag be careful not to touch a power wire that doesn't go to the airbag or module or it WILL GO OFF !***** I would double check with the owners manual if you plan on using the airbag, if not, if you are only using the power for the seat to go back and forth! as well as recline! only hook up the main power wire and the ground wires... See picture... Hope this helps out.. Mjclemm...
Attached Thumbnails Camaro seats in 01 Monte Carlo SS FINISHED !   :)-image.jpg
Old Feb 14, 2014 | 11:28 AM
  #39
MJClemm's Avatar
The Camaro seats I bought are a sort of cloth, not the same as the Monte cloth seats, but really tight knit cloth, so these ones do not have the heaters, however, the leather seats DO HAVE heaters in them, I have an 2010 Camaro with Black Leather seats that do have the heaters in them, and yes, they do ROCK !....
Old Feb 14, 2014 | 11:30 AM
  #40
MJClemm's Avatar
Btw, are they leather ?
