bad amp?
Old Aug 9, 2007 | 09:55 AM
01pacecar's Avatar
Default bad amp?
I'm wondering if my amp has gone south. The right front speaker comes and goes. If you turn the balance and fade to that speaker only and crank the volume you can hear it a little. Sometimes it starts working but it doesn't stay. Wiggling the wires at the speaker and at the amp makes no difference. Also when that speaker is not working right the overall volume of the system is lower than when it's working. I have to turn the volume to about 3/4 to get where it would normally be a little below 1/2.
Old Aug 9, 2007 | 06:51 PM
04 Intimidator's Avatar
Default RE: bad amp?
Mine does the same thing every so often and I've tried the same as you have. I'm thinking about just replacing the speaker.
Old Aug 19, 2007 | 09:25 AM
montecarlolt's Avatar
might be overheating
Old Aug 19, 2007 | 10:06 AM
wiz kidd's Avatar
sounds like a speaker problem to me, i haven't had any problems with the amp in mine yet...a lot of car's dont even come with them. so to me it sounds like a speaker problem
TMoney
Apr 9, 2014 09:32 AM
04chevyboy
Nov 10, 2011 07:39 PM
BigPana
27
Jun 24, 2011 11:37 AM
dirtybird
Sep 26, 2010 12:48 PM
rj
May 19, 2010 07:34 PM
