Audio installation help
I was just wondering if there were any adapters or wires I may need for the install of new kicker 6x9's and 6.5's.
And I was wondering if anyone knew were to run a 4 gage power wire threw the firewall or another way?
Its very easy to install all speakers throughout your car. What I did was bought some factory gm adapters from www.installer.com. if you still want to know how to install them, as well as the amp wire, I will gladly be able to provide you with the "Do It Yourself" instructions.
the fire wall is on passenger side under dash you will see a bunch of wires to it. it will be a tight fit, as i put a 4gauge wire in there.
You will need a piece of metal like an antenna would be the best thing and attach that to the wire. Get you and someone to help for push and pull. Some lube would help to.
From the engine area the wire will come out(look at the alternator then look straight down and it will be there near the bottom). Then just get the wire to be pushed up then attach wire to battery and you are ready to go.
6th Gen ('00-'05): Steering Wheel Button Installation HELP
irace88
08-16-2020 05:03 PM
