amp install on 2001 MC
Speaker Color code MC 2001 2DR Coupe.
LF speaker (+) TAN
LF speaker (-) GRAY
RF speaker (+) LIGHT GREEN
RF speaker (-) DARK GREEN
LR speaker (+) BROWN
LR speaker (-) YELLOW
RR speaker (+) DARK BLUE
RR speaker (-) LIGHT BLUE
LF speaker (+) TAN
LF speaker (-) GRAY
if, with the high-low drive that tells you you can inject your audio to your amp
You car has power antenna?
if so, you could use the same cable that activates it, you just have to make use of a relay, as the current cable is very low.
