amp install on 2001 MC
Old Jun 18, 2010 | 11:41 PM
spiknek's Avatar
Smile amp install on 2001 MC
hey i like to install a 4 channel amp to my 2001 MC with the original fact radio
can some one help please
Old Jun 19, 2010 | 06:33 PM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
What is the amp going to be powering??? speakers or a sub? If its speaker you will have to go around the factory amp....
Old Jun 19, 2010 | 10:10 PM
04MonteLS's Avatar
Sure, I'll come give you a hand. Where you at?
Old Jun 19, 2010 | 11:10 PM
osantisbon's Avatar
you need a converter from high to low. Of this converter RCA audio will take you amplifier.
Old Jun 19, 2010 | 11:17 PM
spiknek's Avatar
well what i want to do is keep the original radio and put in a 4 channel amp with 2 rear spks 2 front spks in the front 2 tweekers and in the back 2 10 inch bass im in Kissimmee Fl
Old Jun 19, 2010 | 11:21 PM
osantisbon's Avatar
Exclamation Color code
Speaker Color code MC 2001 2DR Coupe.
LF speaker (+) TAN
LF speaker (-) GRAY
RF speaker (+) LIGHT GREEN
RF speaker (-) DARK GREEN
LR speaker (+) BROWN
LR speaker (-) YELLOW
RR speaker (+) DARK BLUE
RR speaker (-) LIGHT BLUE
Old Jun 19, 2010 | 11:23 PM
spiknek's Avatar
ok but were do i get the input to go into my new amp?
Old Jun 19, 2010 | 11:25 PM
spiknek's Avatar
and were do i get my remote?
Old Jun 20, 2010 | 08:43 AM
osantisbon's Avatar
if, with the high-low drive that tells you you can inject your audio to your amp
You car has power antenna?
if so, you could use the same cable that activates it, you just have to make use of a relay, as the current cable is very low.
Old Jun 20, 2010 | 09:22 AM
spiknek's Avatar
no i not have a power antena!
