Amp
Old Mar 22, 2010 | 10:30 PM
Enzo354's Avatar
STILL SLOW
Default Amp
I got a used amp from an 04 monte to put in my 2000, the speaker connector works, but the main power one doesnt fit. Does anyone have that part number or a picture of their 04's amps connector?
This is the stock 2000 connector....
2000 amp
I need the 12 pin connector for this
Old Mar 22, 2010 | 10:38 PM
mak330's Avatar
how much did you pay for that amp, i sold mine to a guy on here and he told me that he had to get it reprogramed and all this extra stuff. luckily i hooked him up or it wouod have been a bad deal.
i say take it to the scrap yard and see if you can get 2-3 dollars for it. then take that 2-3 dollars and put it towards and aftermarket one.
those amps are 200 watts max, which means 50x4,
which really means there like 25-30 x 4. most HU push more than that.
from what i heard of the cost of extras its just not worth it to add an oem amp.
GL with it though.
Old Mar 22, 2010 | 10:55 PM
Enzo354's Avatar
STILL SLOW
I dont have the money to get a new headunit, I just need to replace the one thats broken, no programming is required for it.
Old Mar 23, 2010 | 05:42 AM
Hi `Brock,
I don't know if the below links will help or not,
but it's worth checking out.
Notice that Mod `Wayne's post is contained.
If he does not see your thread question & no one else
has a solution, I suggest a PM 2 Mod `Wayne.
Good Luck
2004 Chevrolet Monte Carlo Car Radio Wiring Diagram
Automotive wiring in a 2004 Chevrolet Monte Carlo vehicles are becoming ... crossovers, audio equalizer, car amplifier, mobile amp, car amplifier, ...
www.modifiedlife.com/2004-chevrolet-monte-carlo-car-radio-wiring-diagram/ - Cached
2006 Chevrolet Monte Carlo Car Radio Wiring Diagram
2004-2005 Chevrolet Monte Carlo Aftermarket Car Stereo Dash Kit ... My 2006 Monte Carlo does NOT have the factory amp under the rear deck lid, do all the wires for ... Good luck with your 2006 Chevrolet Monte Carlo amplifier install. ...
www.modifiedlife.com/2006-chevrolet-monte-carlo-car-radio-wiring-diagram/ - Cached - Similar
Show more results from www.modifiedlife.com
GM - Impala/Monte Carlo 2000-2001 Amplifier Amp 10309547 10309548
Factory GM Delco (OEM) amplifier amp for 2000 2001 Chevy Chevrolet Impala and Monte Carlo. 10432571 10289187 10309547 10432572 10289186 10309548GM -
replacementradios.com/product_info.php?cPath=339... - Cached - Similar
Wiring harnesses, car wiring harness, car stereo wires, metra ...
If your not so good with soldering wires or crimping connectors we can .... Factory Amplifier Integration harness 4 RCA plugs to mate to aftermarket radio's pre-amp ...... Impala/Monte Carlo Amp Bypass Jumper 00-01; Amp bypass jumper, ... 2004 Chevy Malibu Plugs into car harness at radio Power and 4-Speaker Will ...
www.installer.com/wires/index.php - Cached - Similar
Bose car amp Car Audio / Video Accessories at bizrate - Price ...
Replacement/addition of an amp in a 1997-2004 Chevrolet Corvette with premium ... in 1997-2004 Chevy Corvette vehicles while keeping the factory amplifier,provides ... 1990-96 GM vehicles with a Bose system using the existing wiring and connectors .... 2007–2009 CHEVROLET® MONTE CARLO & 2007–2009 GMC® DENALI) ...
www.bizrate.com › ... › Car Audio / Video Accessories - Cached - Similar
~> Rock'n Intimidator SS: Rock'n Intimidator SS. JL Audio Custom ...
RocknMonteSS18s's 2004 Chevrolet Monte Carlo SW, MI customized with K&N Intake MSD Ignition Optima ... Eagle Alloys Wheels Custom Sub Enclosure JL Audio Subwoofers JL Audio Amplifier JL Audio Speakers ... Remote mount factory radio. * XM tuner * Sirius tuner * 110v, 300watt power inverter replacing the factory amp ...
www.cardomain.com › ChevroletMonte Carlo2004 - Cached - Similar
Old Mar 23, 2010 | 07:47 AM
Enzo354's Avatar
STILL SLOW
Space thanks for the links Ill dig through them later!
....so mabye this was too challenging of a request for anyone?? Space thanks atleast to u.
Old Mar 25, 2010 | 10:39 PM
Enzo354's Avatar
STILL SLOW
Since no one on here can figure it out.... can someone at least take a pic of the connection on theyre 04 monte, just so i can see what pins the positive and negative are?
Old Mar 26, 2010 | 08:03 PM
Enzo354's Avatar
STILL SLOW
No one?
Old Mar 27, 2010 | 06:10 AM
Maybe everyone is busy, or they just
don't know, or don't care
Why, oh Why
___________________________
`Brock,
Hope someone can `help U
Maybe 2 day ?
Old Mar 12, 2022 | 05:59 AM
Bellyisis's Avatar
This is a bit on & off Amp subject… does anyone have a picture(s) of the factory amp wires that they can post??? I think(I know) mine were cut or my amp was swapped out by a Bodyshop tech when my Monte was rear ended by a tire. The tech was fired since stealing parts off my Monte to rebuild his buddies.
thanks all
Old Mar 15, 2022 | 12:45 PM
thanks all
Better to start a new thread. I am sure someone can help.
