6th Gen ('00-'05): aftermarket gauge help!?
Old Oct 29, 2012 | 06:58 PM
Monroe's Avatar
Monte of the Month -- December 2013
Default aftermarket gauge help!?
Hey MCF members! So i recently bought my first of three gauges to be placed in an A-pillar that i will buy as soon as work picks up. Its a narrowband air/fuel ratio gauge.
Can anyone help me out by telling me how to install it? How it works? Please dont use too technical of words either, or youll be getting the "" face! And also, if anyone has any 2 1/16" gauges theyre wanting to get rid off? I'll probably take em off your hands!
Old Oct 30, 2012 | 07:13 PM
turbo monte's Avatar
I have a wide band air fuel gauge made by aem. I'm not sure how the narrow band gauges hook up...
Have you Google's or checked YouTube for a video on how to do it? Sounds crazy but a lot of my issues were solved by doing that.
Old Oct 30, 2012 | 09:58 PM
Monroe's Avatar
I saw people who had one on their monte on YouTube, but no tutorials. I'll give google a shot!
Old Oct 30, 2012 | 10:20 PM
I believe it goes directly to the o2 sensor, the wire coming off the o2 sensor should be the oddball color, that goes with the purple wire on the back of the gauge.
Old Nov 1, 2012 | 08:55 PM
Monroe's Avatar
And an o2 sensor is?
Srry, im still a rookie at this stuff! xD
Old Nov 2, 2012 | 08:40 AM
Probably shouldn't have bought this if you don't know how to hook it up...
The black and red wire, are your ground and power.
The purple goes to the o2 sensor, that is located on your rear exhaust manifold.
Now after you install it. It doesn't do much, and it is more of an annoyance than anything else. A narrowband doesn't tell the computer much, as it doesn't give the reading that a wideband gives.
Basically when you are idling, you will see the gauge in the stoich range. When you put your foot down it will become rich, and when you let off it will become lean. It's just going to bounce around a lot and not give any useful information.
Good luck
Old Nov 2, 2012 | 08:45 AM
Good luck
I x2 that mike.
Being an old school guy...
In my 65 impala SS it had a Vacuum gauge built in the dash...
Now there was some useful info..when it comes to useing the loud pedal!
for fuel economy!
Old Nov 2, 2012 | 09:40 AM
03SSLE's Avatar
Old Nov 2, 2012 | 11:26 AM
Monroe's Avatar
Looks helpful, 03SSLE! Thanks!
And for the rest of you, I got it from a fellow MCF member for quite cheap. Im looking for cheap gauges to fill a 3-pod a-pillar. The narrowband is just temporary until I can save up enough money to buy the good stuff.
Old Nov 2, 2012 | 11:52 AM
03SSLE's Avatar
I think that is the same gauge you have. You may want to verify your model number with the instruction sheet just to make sure. If that isn't the correct one do a search of Autometer's site and you should be able to find the one you need.
Johnny262626
Jul 13, 2015 10:47 AM
01 Monte SS
14
Jan 21, 2013 11:57 AM
rmorman
Sep 30, 2012 01:18 PM
04chevyboy
Jan 29, 2012 09:50 PM
SaveTheMontes
Jan 19, 2007 08:11 AM
