Adding HID lighting ballasts on a 7th Gen?
Old Oct 23, 2009 | 12:11 PM
flhrob's SS's Avatar
Default Adding HID lighting ballasts on a 7th Gen?
Has anyone done this to their Monte yet? If so which lighting is the best to purchase and where? Is the lighting system "Canbus" (Controller area networked bus system) Or still old school?
Sincerely,
Rob~
Old Oct 23, 2009 | 12:49 PM
sonin66's Avatar
i have, went with the 8000k for lows. i wanna put the fogs at 6000k and for the highs. not sure on your canbus ques, but you could see how the setup is by either googling or ebay
Old Oct 23, 2009 | 01:24 PM
TheMonteMan's Avatar
ive done it. im running 5000k in fogs and low beams. these are the ones i went with. a couple people on my other forum run them and havent said anything bad about them.
http://www.ddmtuning.com/index.php?p...=102&parent=85
Old Oct 23, 2009 | 01:28 PM
RickAKATed10's Avatar
Photobucket
unreal.
Old Oct 24, 2009 | 06:25 AM
The Canbus system is a two wire data highway system in some cars, Similar to computer ether net. I know that on some late 90's to late model Mercedes and BMW's do have it, A good example for instance that when a light would fail, the ECM gets a signal/feedback data from an area controller and it would display an error via the ECM on the dash display, that's right down to a specific lamp being out. I guess our cars don't have that yet.
The real advantage to using this system is it severly cuts down on the number of wires in a wiring harness to just two wires but would require a few more area controller boxes and relays that are controlled only by data.. The savings in copper wire would be significant for the automakers.
Thanks for the info.
As always SIncerely,
Rob~
Boxman420
Jan 13, 2012 09:31 PM
fdp1956
Mar 14, 2011 03:33 PM
berencam
Oct 5, 2009 11:05 PM
Berg01SS
Jul 21, 2009 08:59 PM
06montels
13
Jul 17, 2009 10:59 PM
