5th Gen. Add-On Electronics
Old Jul 17, 2010 | 11:21 AM
cbetts's Avatar
Default 5th Gen. Add-On Electronics
I finally got the "necessities" installed in my '98 Z34.
I bought the car a few weeks ago and quickly realized how much I miss things like bluetooth for my cellphone and music from my iPod. I had an old Dension iPod dock that once was installed in a previous vehicle. I also had a Parrot bluetooth kit that was in my Solstice before I put a Pioneer navigation system in it. All I needed were the right wire harnesses and mounting plate for the iPod dock.
(click pictures to view larger version)
Taking apart the dash was not hard. This car had see a lot of sunlight which made the plastic brittle. All the upper mount lugs broke off.
The center console worked well for hiding all the wires and modules.
While I had everything torn apart, I figured it was a good time to mount the ScanGauge as well. A couple of zip ties holds it firmly in tape/CD storage area. I split the storage and filed a notch to make it easier to run the wires.
Here is the final result. Everything worked like a champ!
Here is the list of parts used:
  • Dension ice>Link iPod dock
  • Pro.Fit Vehicle Specific Mounts-Standard VSM CV-50-94
  • PIE GM9-AUX 1995-up GM 9-pin Auxiliary Input Converter
  • Quick Connect Products ISO Wiring Harness Most 88-02 GM Vehicles
  • Parrot Evolution CK3000 Bluetooth Kit
  • ScanGauge II
All parts except the dock were purchased on amazon.com
ultrarevvin1
Vendor for sale section
Feb 3, 2014 03:37 PM
Nov 17, 2012 08:56 AM
PacerSS
Feb 18, 2011 10:56 AM
augi
Dec 10, 2010 01:01 PM
