2002 Monte Carlo SS 3.8/V6 (Fuel Gauge)
Old Oct 1, 2009 | 02:05 PM
William3742's Avatar
Default 2002 Monte Carlo SS 3.8/V6 (Fuel Gauge)
Removed because i found my own problem, the fuel tank pressure sensor has nothing to do with fuel gauge.
Last edited by William3742; Oct 4, 2009 at 05:36 PM. Reason: No helpful answer with this problem
Old Oct 1, 2009 | 02:07 PM
move your pinky right and turn off caps lock.
also, probably could be the sending unit. there's a nice thread on here about how to replace that easily.
Old Oct 2, 2009 | 07:51 AM
I don't guess you read my post before reply. I said that i had replaced the fuel tank pressure sensor. I had no problem replacing it, that was not part of my question. Don't worry about my caps being on, and try not to be cute in replys that have no value.
Old Oct 3, 2009 | 10:11 PM
RocknSS04's Avatar
My gas gauge actually did full back flips, loop de loops. full circles counter clockwise. It was the gauge cluster. It was covered under warranty, and they aren't cheap, AND you can NOT legally change out a cluster yourself. Check out this thread:
https://montecarloforum.com/forum/sh...ad.php?t=12319
Old Oct 3, 2009 | 10:21 PM
wow, great point wayne, my buddy has an 04 intimidator and his did the same thing, got it replaced for around $400 bucks, never even though about the legality issue.
Old Oct 3, 2009 | 11:28 PM
MAMONTE's Avatar
Sounds to me like the sending unit...but could be the gauge cluster too...
Old Oct 3, 2009 | 11:48 PM
your asking a question in caps like your yelling at us, its hard to read and kind of annoying, he wasnt being a ***** he was just saying...chill everything will be okay, chichi is probably right tho....
....as he usually is
Old Oct 4, 2009 | 01:45 PM
RocknSS04's Avatar
Depends on what your gauge is doing. Like I said, mine was spinning in complete circles. An OBVIOUS gauge issue. If the gauge is not responding, but otherwise working, (ie, no complete circles), then he is right, it probably IS the sending unit. Do you have the DIC? If so, does it read correctly? That's how I knew for sure mine was bad (other than it did back flips)
Old Oct 4, 2009 | 05:25 PM
I have replaced fuel gauge pressure sensor, it has nothing to do with the fuel gauge.
Thanks
Old Oct 4, 2009 | 05:28 PM
That may be true but if people don't have the correct answer they should not reply.
