06 audio system
Old Apr 2, 2008 | 09:19 AM
inssanity21's Avatar
Default 06 audio system
any body change one out?
i hear the computer is tied into the head unit. can anyone back this up or prove it wrong?
i would like to get some more boom boom out of my 06 ss
Old Apr 2, 2008 | 08:08 PM
TheFullMonte's Avatar
Default RE: 06 audio system
nothing really different thanotheryear/model montes. without the factory hu you will lose the interior chimes and steering controls. you can gain the wheel controlsback with Pac's steering wheel interface.
Old Apr 3, 2008 | 06:06 PM
red06SS's Avatar
Dont just pull it out and start cutting wires. You will need to buy the aftermarket wire harness it will run you 130-160. Then its just plug and play. Hope this helps.
Old Apr 4, 2008 | 10:16 PM
awesome thank you. i wouldnt just cut wires im into doing this stuff right. if its worht doing its worth doing right.
how bout the stock remote? i only have a distance of about 50 ft. the owners manual says somewhere around 300. do you get that?
Old Apr 5, 2008 | 08:02 AM
rysZ34's Avatar
It's all about where the sensor is to receive the signal from the remote. My '05 Malibu works great, 100-150 ft. but my '99 Z34 is about 30 ft...I'm not sure what causes that...but I've learned to live with it. lol.
Old Apr 5, 2008 | 10:10 PM
has your 06 been through thecampaign on theremote issues? low range, trouble with remote start and/or complete failure. the dealerwill replace it all from the antenna to the key fobs. our 06 wouldnt work past 20ft.
Old Apr 6, 2008 | 04:17 PM
mavrickf1613's Avatar
Monte Of The Month -- January 2009
I had my stereo done, I have a aftermarket cd deck, I had it installed at my local best buy store, the install wasn't expensive. You will need this harnessif you have the onstar stuff through your car. the lan kit at crutchfield.
http://www.crutchfield.com/App/Produ...p;i=120OSLAN01
Old Apr 7, 2008 | 08:50 AM
how bout if im just getting rid of the speakers? i dont need the harness still do i?
but right now my entire car is apart including headunit and speakers. i am rewiring my subs, and also before i bought the car somone had hit it at the dealership and i was not informed. but long story short now im in it for two grand, but thats including some more paint work that im doing. who ever repaired it butched it. i peeled their bond and adhesive right off.
Old Apr 7, 2008 | 11:17 AM
you don't need the harness to do the speakers but you needthe harnessif you change your deck.
Old Apr 7, 2008 | 09:57 PM
sweet thanks.
are you or any one you know of having remote issues. and know a quik fix. im tryign to avoid the dealership. i dont want to reprogram the computer
